emClient 9 beta
Has anyone tried keyboard-shortcut reassignments in the Beta? I installed eM Client 9.0.534.0 (Win10 Pro), and none of my keyboard-shortcuts work. I’ve reassigned several of the keyboard-shortcuts to the same keys that the Gmail web client uses — e.g., “e” for archive and “v” for move-to-folder — without success.
I’ve even tried resetting all of the shortcuts to default, and then re-reassigning my own keys, but eM Client continues to ignore them. Only the default shortcuts work.
eM Client 8 has been working as expected with the same key reassignments.
@Andy5
Have you tried creating the same shortcut keys with eg: Ctrl or Alt keys in front of what you want ?
Wondering if that would make any difference.
Also what error message appears in eM Client when you do assign custom shortcut keys ?.
Good call @cyberzork ! Yes, if I use a modifier key with the shortcut, e.g. Ctl-E for Archive instead of just e, the shortcut works.
With that said, eM Client 8 works fine with keyboard-shortcuts that don’t have modifiers, so I have plain e assigned for Archive in eM Client 8 — to match the functionality in the Gmail web client. I’m hoping the developers can fix eM Client 9 soon. (They acknowledged the report I emailed to them.)
Since I have upgraded to version 9.0.231 (b25143a) in the inbox I have an email header (the email has no content) that cannot be removed, deleted archived or anything… Is this a version bug or a database issue? If the later, how this could be addressed?
Cheers,
A
You may want to send this post to the beta team… [email protected]
Version 9
Tags display incorrectly in some contacts.
Correct display
Contact 1
Incorrect display
Contact 2
Bug or settings?
I found, what I call incorrect display is due to lack of space.
Simply either shorten the tag names or widen the column.
But it would be better to return to the presentation of version 8 (small color squares instead of an almost unreadable display).
Report it to Beta support… [email protected]
We’ll try to redesign these tag icons to be more distinctive.
Wondering if there is an option in V9 Beta when using the new “toggle dark or light” in the body of the email to automatically save either option for a specific email like eg: Google Play receipts which always need the (light) toggle option or is nearly unreadable.
Be great to have a eg: Save icon next to it :floppy_disk:
Thank you for considering my comment.
Indeed. I also have to switch from dark to light mode in e-mails from the same sender. A possibility to save the behavior would be great. :bulb:
@Jarret_Schwartz
The “recurring tasks” problem not showing in the Agenda should now be resolved in the latest official eM Client V9 Beta (2) 9.0.599 Windows via the ver history page.
Ps Backup first though via “Menu / Backup” before installing updating to any new Beta.
Thank you! Yes, it is working now. It seems to have introduced a new bug though. The tasks seem to be duplicated in the task list at later dates. I know it is that way because if I edit the task both the current and the future task edit. Normally, a recurring task would just show on the due date and then once completed it would show again on the next date but that doesn’t seem to be the case now.
@Jarret_Schwartz
Ah ok. Send that feedback through with a screenshot example to [email protected] .
I will also test that out as well when back home in a couple days.
Will the new release include a 64 bit version ?
eM Client 9.0.599 fixed the single-key shortcuts. Now they work as expected. Yay!
So I’ve had the beta version for some time. At the beginning there were some problems that were fixed really quickly.
Unfortunately, the different scaling for two monitors does not work yet, but otherwise I am very, very satisfied with the current version 9.0.599.
I‘m also happy with the beta version 9 and I won’t go back to version 8. :wink:
Good job guys! :+1:
@Jarret_Schwartz
I have tested the latest V9 Beta and there is still issues with displaying “Recurring tasks” in the “Agenda sidebar” for more than a month view.
I have resent my issues / feedback on that.
