Does EMC not synchronize contacts with Gmail when using POP3 protocol? This is happening with me. Don’t try to convince me to convert to IMAP – I dislike the logistics of it very much.
Thanks.
Thanks.
No, that is because POP3 is a message protocol. It doesn’t sync anything, just gets new messages from the server.
However, you can no longer use POP3 with Gmail, so you will need to setup the account again using the automatic setup, which will include Google Contacts and Calendars.
See: Google ‘less secure apps’ access and what it means for eM Client | eM Client
Thanks, however you can use POP3 with EMC. I am doing it fine. You just have to do a special procedure to get a special password. It is documented here:
