Set default paste
Hi I paste some text, eM Client gives me paste options that won’t go away even though I have set the default paste options 100 times. The stupid box usually gets in the way of the text and is an annoyance.
-If it asks me every single time, it’s not really a default is it?
Also, I never, ever, ever have needed the option to paste in formated text.
If you continue typing, it will go away immediately.
good to know
(here are extra characters because forum posts must be 20 characters long)
Okay, if you keep typing, it might go away. The problem I have is that I’m using a lot of AI tools now, and I dictate the text into EMClient, and it gets automatically pasted in there. So as I keep adding and layering more text, these things pop up, and I can’t see what I’m doing; I can’t see where I am. How on earth can you turn it off? I keep accepting the default settings. They should be accepted at some point, I would have thought.
It doesn’t seem like the original poster’s question has been fully addressed. How do you stop this pop-up from appearing? What is the point of having default settings if they are never accepted as such?
Has anyone seen my question above? It would be great to get this sorted because it’s really messing with my day.
