I am a new user for eM Client. I like the app but the slider on the vertical scroll bar on the right side of the app’s window is much too narrow. In some cases, I am not able to scroll at all trying to use the slider.
You can choose the “Classic or System” themes which have wider scroll bars. Go to "Menu / Settings / Appearance / Themes.
Or if you are using eM Client 8.1/8.2 you can open the “Theme Editor” and customise any theme to have wider scrollbars. “Menu / Tools / Theme Editor”
See @Gary screenshot at end of this thread how to change scrollbar thickness in the Theme Editor.
Note:- Remember If you use the Theme Editor “Save the Theme” first in the Theme editor, by clicking the “Advanced” button at the bottom right. Then “Open and Modify” that theme. The default Theme save directory for Windows 10 is normally eg: - C:\Users\yourname\AppData\Roaming\eM Client
