This error often indicates an issue with the database file itself. While the repair command @skybat suggested is usually the first step, sometimes underlying disk problems can cause this. If the repair doesn’t fully resolve it, you might want to check your drive for errors.
Good call on checking the drive. Database corruption can sometimes be a symptom of underlying disk issues or even sudden system shutdowns. If the repair doesn’t fully resolve it, ensuring your drive is healthy is a crucial next step before considering other solutions.
MailClient.Storage.Data.DatabaseCorruptedException (0x80004005): SQLite Error 11: ‘database disk image is malformed’.
If running the database repair makes no difference as @skybat advised above and all your other apps are ok and scanning your hard disk has no sector errors as @TimTom420 advised then suggest next to create a new database to test.
To create a new database first “close eM Client” and then go to the following hidden database folder below and “rename it” to eg: eM Client-Old Then reopen eM client and setup as new.
If creating a new database then fixes the errors and runs ok “but you need mail, contacts etc out of your original database”, then see my post in the following thread which explains how to do a Partial Restore either from a recent eM Client backup.zip or from a backed up hidden database folder if you backup your computer user profile.
Or see the following eM Client blog page on doing a “Partial Restore” in “Offline mode” part way down the following page.
How to Check Disk for Errors using Command Prompt:
1./ Press Windows Key and tope CMD in Search
2./ In Right Panel Click “Run as Administrator”
3./ In new window type chkdsk C: /f/x/r - then Click Enter
(there is a space between chkdsk & C: or other drive)
4./ If drive is in use tyoe Y & Click Enter
5./ System will restart PC & disk will be checked on boot
(if possible any errors will be repaired)
skybat
¡Buena suerte!
If as you say you are NOT certain it will do no harm
and possibly some good to carry out both procedures
that I have posted above in the order the order they
were posted AND take note of all that @cyberzork
has posted
skybat
¡Buena suerte!
