Hallo.
During the installation of the new version, I get the message: The function you want to use is located on a network resource that is not accessible.
Setup is looking for the source:
C: \ Users \ User \ AppData \ Local \ Temp \ ejtna4de.fiz \
I can’t continue with the installation.
Please help / advice.
This is an issue with the OS, specifically the Windows Installer.
If you do a search on the Internet, you will find solutions that describe how to fix this.
Once you have fixed Windows, try the install again.
Greetings to all.
So I solved the problem by force
I backed up the complete eM Client and uninstalled it using “Revo Uninstaller” (perfect program), including registry.
Then I installed again.
