Otevření aplikace do stavového řádku
Dobrý den, lze nastavit aplikaci tak, aby se spolu se startem OS, což mám nastaveno, otevírala do stavového řádku? Takovou funkcionalitu jsem nikde nenašel. Děkuji
Hello, is it possible to set the application so that it opens in the status bar when the OS starts, which I have set? I have not found such functionality anywhere. Thank you
Using Windows you can set eM Client to automatically start minimised on the taskbar. See the following page thread.
Using a Mac, just open eM Client and minimise it. Then when you shutdown, tick the box to automatically start open apps on OS popup box.
