Navigation option "Shortcuts"
I have been watching eM Client for a few years now.
What I am still missing is the possibility to add shortcuts in the navigation bar to organize the view into link groups and shortcuts of my choice.
Is this planned for the future?
Best regards
Oliver
You can create on the Toolbar in eM Client V10 eg: custom “assigned shortcuts” using the “Quick Actions” menu as in the following thread link post example to eg: Create a Task from a message.
Hello cyberzork,
thanks for your quick reply, that’s a great tool. But unfortunately not what I meant.
I miss the shortcuts item in the left-hand navigation, like in Outlook. In my opinion, this is a great function to personalize your menu so that it is the clearest for you.
Here I have illustrated what I mean.
Unbenannt-1
Best Regards
Oliver
Since I haven’t received a reply so far, I assume that this function is not available in eMClient.
It would be great if this function were integrated into eMClient so that we could finally break away from Outlook.
Regards
Oliver
It’s a shame that this function is still not available!
There is now a Sleekplan request to be able to add left hand folders to the toolbar which i see also alot of Postbox users also did “on a separate toolbar”
eM Client might be able to possibly add the ability to combine mail folders or favourites “into the current navigational toolbar” without having to add a separate toolbar just for what you want.
I have now taken a look at Postbox. The only thing I can do there is to divide all the mail accounts into account groups.
The “Shortcuts” function in Outlook offers the user complete freedom of organization. I also think it’s a good solution in Outlook to use a separate toolbar for this. This gives users the option of using the standard toolbar with mail folders and favorites or the toolbar with self-sorted shortcuts and the subdivision into folders.
Translated with DeepL.com (free version)
Another new version, and there’s still no option on the left side to customize your mailboxes and organize them into groups, like in Outlook.
It’s a shame there’s still no way to finally say goodbye to Outlook.
