Multiple drafts being saved, not deleted after sending
I’m using eM Client v10.3.1720 under macOS 15.4.1, in conjunction with a Microsoft Office 365 service (eM Client is set up with Exchange services). I’ve been noticing over the past few days that my Drafts folder is growing.
When I look inside, I see multiple copies of draft messages that I’ve been working on, saved a few minutes apart. I believe this is because of the selected tick box option within eM Client to save drafts every X minutes.
What is surprising me, however, is that the drafts are not being deleted when the message is finally sent, which would be what I’d expect when using Outlook, for example. Is that the intended behaviour? Have I missed a setting? Or might this be a bug?
Any thoughts on this?
Today, I tested v10.1.4828 under macOS 15.4 and found it did not leave multiple drafts undeleted after sending. This is only happening with v10.3.1720 for me and I’ll be manually cleaning up dozens of drafts remaining in the folder.
Any ideas or do I need to open a VIP Support case?
Yes I would lodge a support ticket via the VIP support page](https://support.emclient.com/).
I personally carn’t replicate that problem on my Mac OS 15.4 with the same v10.3.1720 using my own IMAP accounts. So could possibly be an issue with Exchange type accounts or something else affecting your specific account in some way.
The only time I’ve had that happen with any version of eM Client, is when I have forgotten I already had draft emails and started new mails so then ended up having to delete drafts later.
Ah! OK, thanks for letting me know, @cyberzork, much appreciated.
I was about to post an update but you got in there first. I’ve been going back through eM Client (both 10.1 and 10.3) and Outlook in parallel. I noticed a few things:
  • Messages sent from 10.3 earlier this week were still present as multiple drafts (saved every few minutes while composing them) within my Drafts folder; they’d not been cleared out when sending
  • Use of 10.1 from later on during the week didn’t have this issue
  • Checking Outlook, the draft messages lingering in the Drafts folder are real
  • Using 10.3 today, the situation may have changed and copies might not be stuck in the Drafts folder; drafts composed today do not show up in Outlook like they did earlier this week
  • But… there are messages visible in Drafts. Checking Properties, it emerges the ones sent today are part of a conversation and are found in Sent or in my Inbox, but are showing in Drafts. Switching Conversations on/off makes these recent drafts disappear from the Drafts folder, but not the ones from earlier in the week.
There may be different things going on (e.g. a server issue vs. the way Conversations work, and I’m getting used to them). I’ll contact Support, but thought I’d provide an update in case it is of use to anyone else too.
Hello.
I also have same problem. I delete and re-add account for fix but it happened again.
It started after latest update. I just bought this application to organize my mailbox but app is failed, as I can see.
I checked all previous topic but there is no solution for this.
I’ve submitted a Support case and will let you know if we get to the bottom of it. :slight_smile:
Same behavior for me. Happens in Mac and Windows and only for Exchange (not IMAP).
Oh, interesting. It was not just me, then!
I submitted a case for VIP Support at the weekend and they got in touch the next day. They provided a link to a development version (v10.3.1808) and I did a quick test.
I began a draft and then edited it three times at three minute intervals. Under the previous version, I would have seen three, separate drafts being saved and then they would not be removed after sending. With v10.3.1808, I monitored the Drafts folder and only saw one draft present and being updated. When I sent my message, the draft disappeared from Drafts, as it should.
I’ve only done one test, but it looked promising. Hopefully this means the development version, and next release version therefore, fixes this issue for anyone who had it!
I may have spoken too soon. It looks like it doesn’t save multiple copies of a draft message anymore, which is good, but the Inbox and Sent items are appearing in the Drafts Conversations/threads. I’m passing this information on to Support…
I also noticed, it happens only in some exchange accounts. Not all of them. I sent log details to support team but my em client shows 1 unread message now.
But I don’t have any unread message. I expect to use this app without any problem. But right now I am planning to find different app.
Is there any update for this topic ??
I contacted VIP Support a couple of weeks ago and they were speedy with the first reply. I sent a few updates to keep them informed and they got back to me about a week after my initial support request, and it sounds like they have noticed issues with some Exchange accounts and have probably been looking into the issues. So I’m sure it makes it more difficult to track down if it does not affect everyone uniformly. I’ve sent a video of what I’m seeing to help them with the debugging process and we’ll see what they say.
I also sent some logs and that’s it. I am waiting for update. I hope we can get ASAP.
The exact same thing happens to me, every email I reply to from the new version of eM Client 10.3.1720 running on MacOS 15.7 ends up in the drafts and sent folders.
They sent me 10.3.1968 version. And it’s working without any draft issue.
I’ve just received a link for v10.3.1968 too. I’ve installed it and did a brief check a few minutes ago. I’m still seeing Sent and Inbox items in the Drafts due to the Conversations view, where switching off Conversations in the list makes them go away. I’ll check the indexing of my folders and see if it persists.
Now I get one more update and everything is working without any problem.
Oh! Newer than v10.3.1968? Which version do you have?
I have 10.3.2015 (5ef8fdd)
OK, nice. v10.3.2040 is out now too. :slight_smile:
