The transition to em client from Postbox has gone quite smoothly, One email account is on gmail and a couple of others on a hosted domain. Those mailboxes are setup for IMAP so I had no mailbox contents to transfer. I was using PostBox and now using em client to view and interact with email on those remote servers. This made the transition easy. I transitioned to em client on day 1 and stopped using PostBox.
What went easily.
em client is pretty good at setting up the email account info, finding the server names and port settings. I own a couple of domain names and em client somehow detected my obscure server names, I only needed my email address and password. em client did the rest
I messed up the themes in em client and somehow created an “access denied” situation in the em client app’s folder in Windows which I could not correct. I needed to un-install and re-install to reset em client. Re-setting up the email imap accounts was fast.
Customizable theme colours. It was confusing at first finding the correct parameter to change because the appearance of the user interface can be customized for font color and background/foreground colors, the number of configurable parameters is considerable.
I initially ran a second instance of em client using the “/db location” parameter to separate work email from personal email so I that I wouldn’t inadvertently compose a work email from my personal account. Later I found I could have my work email in a New Window which served the same purpose. Signatures correctly appear depending with the account which has the focus. So far I haven’t messed up and sent work email from my personal account.
Where I had problems: With themes. I’ll write a separate post. I’m not entirely sure but I can customize the UI with te Theme Editor but I need to save the new theme and load it to have an effect rather than the changes persisting. When I exited the Theme Editor, the theme reverted to the old settings. Edit > Save > Load Theme > Apply.
So far, I’m happy with em client to manage 3-4 email imap accounts. Speed is good. Search is fast. I previously tried Thunderbird but it would freeze up on me manging the same accounts.
What’s missing in em client that was in PostBox is filters that can edit subject lines. I would prefix certain messages depending on contents of subject lines (I receive auto-generated messages from the same sender but with numbers in the subject line. Based on the numbers I change the subject line by adding text)
I’ll update as I get more use of em client. So far so good.
