I’m on version 9.2.2258 (7080479). I select Backup from Settings. The folder C:\Users\jk_bi\Documents\eM Client is present and that is the path I accepted in Settings. I hit Accept and nothing goes in that folder. I hit Save and Close and the come back and hit Accept. Still no backup appears. I have viewed the tutorial, but it isn’t working. Please tell me what I’m doing wrong or what to do to manually create a backup.
Also, will the backup contain everything - mail in folders, contacts, calendar?
Thanks for your help.
Once you enable the automatic periodic backup and save settings, it will normally create a dated backup.zip file in your specified backup folder within the next 24 hours as per the task scheduler.
If it doesn’t appear or you need to modify the backup schedule and you have Windows, see the following thread on the subject…
To do a manual backup, click “Menu / Backup” (Pc) or “File / Backup” (Mac). You can see when the backup is complete in Show Operations via clicking the drop-down on the right of Refresh top left. You will th n see the backup zip appear after that once completed.
Yes it backs up everything within eM Client.
