Since yesterday information about the Mailsploit vulnerability is worldwide available. On the infopage at https://www.mailsploit.com/index there is a Google Sheet attached with tested mail clients including eM Client. eM Client is listed as not vulnerable but if you make the test with your own mailaddress at the same page, the sender address is spoofed. At least in my test with the actual installed version 7.1.3.xxxx i receive mails with the sender [email protected] instead of [email protected].
Is there a newer version which is fixed, available? If i try the check for updates from within eM Client, i cant find a newer version.
