. . . I suppose it is just more normal to find proper words still being used here in the UK. What is considered antiquated in the New World, is still relatively new here.
In this case casual refers to the sender, not the message, meaning someone who does not regularly send messages. Hence, casual messager, not casual message. I wrote it after all, didnât I?
@mikeyww
Which eMC version are you using?
Did you read the rest of this thread? in particular this by Gary:
Gary Curtin I can confirm that 7.2.36694 has this bug, so if you are using it, uninstall it. Then you can and download the previous version of eM Client from the Release History.
In the next release, this has been fixed. It should be posted to the site soon.
and this :
Gary Curtin Yes, as I commented above âChoose NOT to delete the database when prompted, then all your settings and data will be there once you have installed the previous version.â
If in doubt, make a backup using Menu > File > Backup before you do anything.
Gary also recommends to download eMC v7.2.35595 in case v7.2.36465.0 also has this bug - that version also had several bugs.
Sorry - maybe Iâm dense, but I donât see the point to report a bug thatâs been acknowledged and has an advisory what to do about it till itâs fixed.
If everyone that runs v7.2.36694.0 starts reporting the same bug,without reading
the temp solution, weâll have many pages of âme tooâsâ âŚ
In some cases, developers make decisions based on the volume of users who report an issue or experience. If thatâs not the case here, then all the better! I am happy to hear it.
Youâre right, but this is a forum for free users,although eMC staff jumps in with serious problems.
Anyway, it has been reported that an unpublished fix is out,
so itâs just a matter of time that itâll be ready for publishing.
Maybe if you buy a 100 licenses you may get the fix sooner lol
I have version 7.2.36775.0 and there is no problem with saving images. I understand that you get that version, if you download eM Client fron the main page:Â https://www.emclient.com/?lang=en
No idea, why it isnât mentioned in the Release History
The actual address for download is https://www.emclient.com/download. That should always download the latest version. Apparently 7.2.36775 has not been tagged as punished, that is why it is not showing in the release history, nor is it being offered through the update option in eM Client.
I just installed the latest update - 7.2.36908.0, and I still cannot âsave asâ an image thatâs in the body of the email. It only lets me save as an eml file.
I have the very same version that you have and I can save all images.
But you donât go to âsave asâ but right-click into the picture and select the second entry on the drop down menue âSave image asâŚâ
