1 Remove eMClient from startup.
2 Create shortcut of eM Client.exe in C:\Users<user name>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
3 Right Click > Properties > Run Minimized
martes 25 enero 2022 :: 0811hrs (UTC +01:00)
I do not understand, are these comments or requests?
¡Saludos desde la soleada Sevilla España!
Skybat
[email protected]
These are comments fot temporary fix until the request for minimized startup is fixed.
You have minimize to system tray option but still do not have the start minimized option.
I had to manually setup the start with windows in minimized tab instead of it eing a given.
Thanks
martes 25 enero 2022 :: 1632hrs (UTC +01:00)
What you have written and suggested does not work!
Skybat
[email protected]
