How to remove ssl.gstatic hindrance?
2021-03-16_9-23-36
Since a few days typing new messages has become a nightmare. Keystrokes appear often with seconds of delay during which the busy cursor is shown. When sending the message the above window pops up.
I have re-installed eMClient but the problem remains.
I found one earlier message on this forum re ssl.static but I didn’t find a solution there to remove this unwanted linking (may be my ignorance)
Thanks in advance for your help.
Arie de Ruiter, Amsterdam
Can you disable any templates or signatures, then start a new message (not a reply or forward) and see if the same issue is present?
Hi Gary,
Sending a new message gives no problem.
Arie
The issue is not unique to eM Client. I did a quick search and other email clients have the same issue when replying or forwarding a message with these Google links.
Only “solution” I see out there is to just delete these messages and don’t reply or forward them.
My other mail reader - the standard Win 10 Mail app - doesn’t generate this window for the same message.
So, comparing its file display with that of eMClient I realized that by default I never select the privacy option “Show images…” See capture 1 in the image.
ssl-gstatic-problem
Once I do that the icons in front of the image links in the message change from capture 2 in the attached image into capture 3 in the attached image and all problems appear to have disappeared!
But for potential privacy problems??
Please see @cyberzork’s comment:
