How do I set eM Client to move to the NEXT (newer) message (i.e., move UP the Message list) when deleting a read message, instead of the PREVIOUS (older) message?
How do I set eM Client to move to the NEXT (newer) message (i.e., move UP the Message list) when deleting a read message.
There is a Sleekplan suggestion “for a directional delete to move up the list after deleting” rather than moving down the list as most mailers do.
So you can vote for that suggestion below.
It will be included in the next “Postbox oriented” bigger update in couple of weeks
@cyberzork , @Michal_Burger — thanks!
Any news on this update? It looks like the last one was November 7th. If directional delete is the, I can’t find it.
Any updates on this version?
The latest V10.2 “now has the directional delete” available in the Settings. See my post.
Also you can “jump to the next newest” or “previous message” via new one-step shortcut keys.
See the V10.2 blog for all the new features.
You can download the latest V10.2 via the below page.
Note: Before upgrading make a manual backup via “Menu / Backup” incase you need to restore for any reason. Also close eM Client before updating.
Thanks, glad to see this feature.
But there seems to be an issue/bug.
You have set to go to previous on delete and it does that (great!).
But when you get to the last message, instead of closing the window (I have set to show in separate windows) it will instead open the next message.
Do you know if this will ever be fixed?
