Hey,
couldn’t it be just because of some maintenance of maild_data.dat? I have aprox. 1.5GB of e-mails there, but the data file is 2.5GB and slooowly is getting smaller.
Now, in my case it propably was because of the fact, that I have migrated from that slow outlook 2003… Since I’m using POP3 for everything (with mails stored on server coz of company policies), the process was as follows:
- Import into eM Client from outlook
- Leave the import as it is, set-up all accounts not to delete any messages from server
- Download all messages from all my mailboxes
- Delete everything from recieved inbox (hey, there would be duplicate e-mails…)
- Sort out the folders imported from outlook
(yeah, i love local folders
now, the eM Client is slow, but still usable. The fact of above procedure is, that it created 3GB database file with e-mails - and than I deleted half of them. Now, when eM is running something is happening on my HDD big time and the datafile is getting smaller.
So, I tried small test… I backed up my database folder first. Then I downloaded sqlite3.exe and ran a vacuum command on the mail_data.dat -> result was 1.5GB mail_data.dat file (it was done within 5 minutes). When I launched eM afterwards, it was fast like hell!
However, since vacuum (as per my understanding) might reset some of the options in the database and I don’t know how precisely sqlite works, i loaded the backup back and am just leaving the eM running with high priority even when i’m not using it. Simply, i have no idea what you guys are doing with the database inside of em and i love my e-mails too much to be experimenting with the core one :-))
So - couldn’t this be a problem? If @szlevi is getting a lot of spam and quickly deleting it … maybe there is a vacuum in the queue of sqlite which makes em slow to respond … somehow.
As I said - full vacuum (which requires another 1.5gb of disk space in my case) helped and solved the matter (but i’m too scared to live with the vacuumed database though). the auto-vacuum or some other used procedure might not use that much of disk space (really - it just slowly decreases the data file size)… but couldn’t that be the cause of the slowness in this case? Deleted, but still physically present e-mails?
It’s just an idea, don’t beat me up…
P.S.: I disabled sidebar and skype interpobality in my case, and file is still getting smaller at a snail rate
P.S.2: i found out about vacuum and used command from this site: http://en.kioskea.net/faq/2285-compac… (nobody try it! for sake of your mails…)
