I’m running 4.0.14522.0
I’m not sure what the build is of the current download, but maybe someone from eM Client can give you a link…
I get this problem too.very frustrating to keep waiting for a mail to load
Upcoming version 5.0 will solve the problem.
Had this exact problem and \DbRepair.exe" /forcerebuild fixed for me
System.Data.SQLite.SQLiteException: The database file is locked
database is locked
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at DbRepair.DbTools.OpenConnection(String fileName)
at DbRepair.Form1.CheckCorruption()
at DbRepair.Form1.Check(Object state)
Whats this one mean?
this means that database is used by external program, do you use any kind of your own backup tool?
Like copy to cloud, or Windows’s backup etc.
It also can mean that database is broken but that situation throws out usually different messages.
so please check if any of your programs touch your database and also tell me if you can use eM Client now or this message is shown everytime you want to turn eM Client on.
best regards
Jan
