Most mornings I arrve at my computer to find that emClient has died over night. I dutifully restart it with my email address in the box; hoping that this will be the day I get an answer.
Are others getting this and is there a cure?
You need to allways exit / close eM Client before the OS shuts down or you will usually get database checking on startup as the database is still open in memory. This can happen if eg: Laptops run out of battery power overnight and the database is left open so eM Client will then check on startup.
If you are already exiting / closing eM Client before the OS shuts down, then you might have an actual database corruption and may need to create a new database by “closing eM Client” and then “renaming the current hidden database folder” to eg: eM Client-old and then reopen eM Client and setting up new.
If creating a new database then fixes the problem, you can then restore your mail from your old database” via either the hidden database folder or from a backup as per my post in the following thread link below.
https://forum.emclient.com/t/emails-missing-from-backup-when-restored/101556/2
Or see eM Client support page blog on Partial Restore “part way down the following page”.
https://www.emclient.com/blog/how-to-restore-backup-in-em-client-614
I am closing emClient now before I go to bed. I never turn off the PC tower. It gets re-booted when I apply updates.
Will see how things go this week.
A
