Just reaching out to see if anyone had any updates on this at all? I moved to MailBird, but it’s is so long winded in terms of moving emails, finding folders, dragging and sorting. Then the window is not very easy to look at in conparision to EMClient. I really want to go back to EMClient, but I can’t just have emails disappearing. I contacted Support (As I pay for a License) and they said:-
'To do that, please go to Menu > Settings > Advanced and click on the Clear Logs button.
Then select the IMAP option next to the email account where the message is disappearing from, and also the one you are moving from if it is different.
You will need to tick the boxes so they turn blue with a tick in it.
Click on Apply and OK.
Restart eM Client.
Find a message you want to move.
Select the following message (the one that is going to disappear) and somewhere in the message body, right-click and choose Properties. Make a note of the UID.
Next select the message you are going to move and somewhere in the message body, right-click and choose Properties. Make a note of the UID.
Make a note of the time, and move the message, reproducing the issue.
Restart eM Client again.
Go to Menu > Settings > Advanced and click on the Send Logs button. Please include the time and UID of the messages you moved, and the UID of the message that disappeared.
You can then untick the selection you made earlier, and click on Apply and OK.’
So they just don’t understand that we ‘DON’T KNOW WHEN OR WHAT EMAIL WILL DISAPPEAR’. It seems to be totally random. And where does it go?! I have no idea.
Any ideas anyone? I was thinking if we should set up a ‘copy to’ where we copy every single email (from a given email account) to another account, that isn’t in emclient. Then, we can periodically check the ‘copied’ account and see if there are any emails in there that have been deleted. If we don’t put that account on emclient, then we may see patterns.
