I removed all eM Client apps, files, registries and reinstalled on windows 11.
When I install the app opens and looks OK.
If I exit the app, it will not reopen and I get this message
“Windows cannot access the specified device, path, of file, You may not have the appropriate permission to access the item”
Hi, sorry for the late reply.
Could you please tell us:
- Your Windows version and your eM Client version (Menu > Help > About, while it is open after the reinstall).
- How you try to start it again: from the Start menu, a desktop shortcut or a pinned taskbar icon? An old shortcut from version 10 points to a path that no longer exists, so please try starting it from the Start menu.
- Do you use antivirus or security software with folder protection (for example Windows Controlled folder access)? If so, check whether it blocks eM Client.
- Does it start again after a Windows restart?
Best,
eM Client Team
