Two emails that I deleted are in the trash but do not go when trash is emptied.
They are dated 12-Jan and the contents don’t show.
They are not on the server outlook.com.
If you have Windows, run the following command below as per @Gary post from the following thread.
Gary Leader
An e-mail in Trash that won’t delete - Mail - eM Client
Close eM Client and open a Windows Command Prompt. Not a powershell, but a command prompt.
Paste in this command:
“C:\Program Files (x86)\eM Client\MailClient.exe” /dbrepair
Restart eM Client. Any undeletable messages should be removed.
I pasted in the command but the command was not recognised.
So did the following in command prompt:
cd c:
cd Program Files (x86)
cd eM Client
MailClient.exe /dbrepair
That worked OK.
Glad it worked.
The reason the command was not recognised the first time, was because you excluded the leading " which is an easy mistake.
The command is:
