The new Theme Editor in the upcoming version 8.1 will make this really easy, both identifying what you are changing and choosing a color. The real-time preview is excellent.
what is the correct item to change the color of the Account Name / Emailadress on the left side?
<TreeViewColors>
<FirstLevelForeground description="Text color for the first-level text in a tree structure">#8B8B8B</FirstLevelForeground>
dont work
can this not be changed?
ah ok…i found it:
theres to…and the second on <MainFormTreeViewColors> must be changed.!
Yes, I missed the second line, sorry.
You can upload your theme to the user gallery.
Does anyone have a theme that is similar to the MS Office 2019 Dark Grey?
Hi Ncruze, I like your Aluminium Matrix Theme.
Can I get it?
Yes, @Ncruze, that is a very nice theme. Maybe upload it to Themes (emclient.com)
@Gary I sent it to them [email protected], they said they were going to put it up on the site but never did.
Sure thing @Jo-HH
The file type isn’t authorized for upload here. Email me and I’ll send it to you.
Fine
It will be nice if you sent it to:
Thanks
Hi all - I’m trying to create my own theme, but am having trouble controlling the colors of a couple of items. Can anyone advise me if I can control the colors as identified in the attached screenshots?
- The image used for Local Folder
- The text for ‘Mail’ and ‘Phone Number’ in the Contact Details sidebar
Appreciate any assistance!
jueves 28 julio 2022 :: 0809hrs (UTC +01:00)
Hey @drzsk
There is a specific place in eMC where User created Themes can be submitted
and checked before being made available for download;
where there is a link to submit themes
Personally I would never download something from the Cloud unless I was
100% certain of the source, particularly from a free service.
¡Buena suerte!
skybat
Hi, does anyone know which setting to change to remove the red/orange line at the top/bottom of the selected item - “All Inboxes” ?
martes 20 diciembre 2022 :: 1030hrs (UTC 0000)
Hey @Mike_Pugh
Unless you really know what you are doing do NOT edit the XML file, use the Theme Editor in eMC: Menu ->Tools ->Theme Editor →
Treeview->Selecteditemborder ->Select the box to right & click →
I am set to Transparent or you can use your background color ->Save or Save As
Close and restart eMC
BEFORE you start make a Backup in case you mess it up: Menu ->Backup
¡Buena suerte!
¡Saludos desde Banjul la soleada en Gambia!
skybat
