Nice and clean suggestion this code adds red line as a separator to contacts and email
#F99999
Replace F99999 with another color black maybe
#F99999
Thank you for the suggestion. I changed something in the main grid section. Here is the new version.
Nice
How did you get the picture of your theme into the code . what tool are you using.
would like to update mine with the picture as you have it. Thanks
It is described in the message of shanna.
https://forum.emclient.com/emclient/topics/themes-in-em-client
"Bryan, you can add a thumbnail to a theme by taking a screenshot, using the top left portion, and reducing it to 80x80. Save it as a 24-bit PNG. Run it through https://tinypng.com/ , then encode it as base 64 data using this link
http://www.askapache.com/online-tools/base64-image-converter/
Then take only the data portion (after the comma) and put it into the
base64 data here
tag at the bottom of the theme file."
New version:
Here is the code for your theme:
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
Thank you very much
https://www.dropbox.com/s/ul972b7z4s7tczv/Moderne%20CM.emtheme?dl=0
A green theme
You can criticize if you want
Jack CM
I like the green Jack (just like the fish), but there could be more contrast in the blue buttons.
https://www.dropbox.com/s/eit7b2nw0eq4em4/Moderne%20CM.emtheme?dl=0
note taken into account
thank you
Hi Richard,
Yes, aimlessly looking around for new themes for eM Client, found, downloaded and installed yours,
IT LOOKS GREAT!
So, what did you use to make it, please?
In advance, many thanks!
Trial and error. Copied the original classic theme then found the fields one by one and tried different colors. No tool just brute force.
Some of my notes Please note some info may have changed over the months
Mass change
Classic theme
#FCFCFC replace #46A3FF or 66B3FF
red line in contacts
Header
FOCUSED COLOR on mail window
CHANGE TO light ORANGE #FADBB7
Thank you, Richard!
First, for a VERY good-looking theme. I am using your ‘latest’, with the orange highlights!
Second, for a speedy reply!
I get tired of looking at the same screens and window designs all the time, so, being a true Gemini, I change things often! LOL
Having built websites for years, mostly using good ol’ HTML, and learning by the ’ B rute F orce’ method, I’m not afeer’d of hammering away at code to get what I want.
Have a _WONDERFUL_ Thanksgiving, and a _TERRIFIC_ Holiday Season!
Warmest Regards from Southern Florida,
Bob
Just a quick follow-up, Richard.
I really like your theme!
Thanks again, and here’s to a Happy and Prosperous Holiday Season!
Bob
Anybody who has the skill want to tackle an “accessibility” theme? By that I mean light (white) text on a black background? Some of older folk need a little help reading, and with the modern, subtle, coloring used, often times have a hard time reading any text or emails.
I have worked around this by changing the default text color to white and background color to black, but that only applies if I have the client default to plain text email only. It works, sort of, but only for the fields where text lay, so in essense, there is a black box with white text surround by the rest of the inbox field as white. Looks … well … odd. And it is.
Any help would be appreciated. I am trying to get away from Thunderbird, but the ability to view in a modified simple HTML with reverse contract makes this hard. Hoping someone has a trick up their sleeve here.
Have you looked at the DARK theme that is in the version 7 ?
I did - it only changes the windows UI, but the email is still displayed with the standard fonts and colors.
Hi Michael,
I’m one of those OLDER FOLK you refer to (73+) and I recently started using Richard Mourino’s beautiful theme!
The blue border is nice and bright, and the underlined emails makes them stand out nicely.
Also, I went into the Menu/Tools/Settings/Appearance/Lists and adjusted the font sizes to suit my visual needs (all set to Times New Roman 12pt Bold is good for my ol’ eyes).
Hope this info helps you in your decision.
Have a VERY HAPPY HOLIDAY Season, all!
Warmest Regards from Southern Florida!
Any news for a new location ?
How do I post my theme ? There is no attachment capability on toolbox I’m seeing.
Thanks !
