The fix to the leap year problem is in this update: http://www.emclient.com/dist/v6.0.249…
Hello Lukáš,
this error was triggered yesterday by the leap year day. Unless you have your calendar set one week earlier, you couldn’t have encountered the same issue.
The leap year bug is fixed in this version - http://www.emclient.com/dist/v6.0.249… - if that is really your problem.
If you encounter a different issue, make a post about it on the forums so we can assist you in solving it.
I was just given the V7 update. I have installed and tested and I no longer have Month view issues on v7. I also tried resetting system date to February 29, 2016 and browsing February in Month view without issue.
Here is the fix for the leap year bug for version 7 - http://www.emclient.com/dist/v7.0.24927/setup.msi
Anyone know how to set the problem status to “Solved”?
