Zoho recently added support for carddav. They explicitly call out support for eM Client for caldav and this works perfectly. With carddav, putting in the short form URL https://contacts.zoho.com/ doesn’t work - the error message from the error log reads
Subfolder synchronization for folder “Zoho-Carddav” failed due to the following error: OK
no addressbook is created, and no contacts are found. From looking at logs from other devices (so may not be 100% relevant), zoho responds to https://contacts.zoho.com/.well-known/carddav with a redirect to /carddav/userid/default.
When I change the URL to reflect the redirect above - https://contacts.zoho.com/carddav/userid/default the error I get is
Subfolder synchronization for “0” failed due to the following error: Not Found
The Zoho documentation recommends using this long for Thunderbird-lightening with the SoGo connector
https://contacts.zoho.com/carddav/userid/default/contacts
When I use that, there is no error, but no addressbook or contacts either.
I’ve contacted Zoho, and they are comfortable that the problem is not theirs, as the short form works for Apple devices and DMFS Carddav-sync on Android and the long form works on DavDroid on Android and Thunderbird.
I am using eM Client 7.0.26653.0
Any ideas how I can get this to work please?
Lastly as Zoho has finally added carddav, would it be possible to add Zoho as a config option? Given the only info needed is login information and everything else is static (IMAP changes from a [email protected] to a private domain - but again, its very simple), this should be relatively simple once carddav is working?
Thanks
Alan
