ZARAFA Protocol violation
Hello
I want to use emclient with our zarafa-server. IMAP.
When i try to sync i got this this error message:
FLAGS (\Seen))
Exception:
Protocol violation
Line FLAGS (\Seen))
Greetings * OK [CAPABILITY IMAP4rev1 LITERAL+ AUTH=PLAIN] Zarafa IMAP gateway ready
Parse error here -:utecht"" “utecht.net”)) NIL NIL “”) BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY REFERENCES)] {2}
Is there a solution?
meiko
can you send me IMAP logs? Tools - settings - advanced, check IMAP under your account, apply and restart eM Client.
then try to synchronize and after that send logs… to galis@emclient.com together with this topic’s url.
after this you can turn logging off.
with regards
Jan
