Hi guys,
I just experienced on my upgraded Win11 that the emClient Tray icon was not showing up when closing or minimizing to tray.
The workaround / fix is to uncheck the setting (click apply or ok then) and then reenable the desired setting. After that the tray icon shows up when minimized to tray.
Also if not visible please make sure to check that the tray icon has not moved to the expandable menu.
Best regards
Petr
