Why is there now two columns of emails showing? Primary and other. Is it possible to just get back to one column? The two are not in sync and there are cases of an email only showing up in one of the columns.
This is because you chose to use Categories during the installation, so some of your messages will be in the other category tabs.
If you later decide not to use categories, you can disable them in Menu > Settings > Mail > Categories.
Please see our video here which highlights the new features you have enabled.
Big Problem with this, when I try remove the Categories option (and every other attempt to change anything in Settings), EM won’t let me!
Get the msg: “Operation not permitted”
And now EM has locked up! I’m not having a very good experience with EM.
If you have Admin user access then could be a problem with the installation folder permission , or could be a problem where the database location is that might have a restriction etc. Unknown.
Suggest if you have a current active paid license, to go to the VIP support page and login and lodge a support ticket for official assistance.
Also let them know what OS & ver you have, and what eM Client version you are using.
