Where are my sent emails going? Because they aren’t going out and I can’t find them? Using AOL mail to send doesn’t work. Gmail works fine.
There was a similar post 2 days ago. The suggestion was to install the newest version. That let me see them in an unsent folder, but didn’t fix the issue.
The solution was to change the SMTP port from the default port 25 to 587. Then they went out fine. Problem solved. But the default SMTP port for AOL accounts is wrong.
