Hi all,
I know that emClient uses Internet Explorer to visualize HTML content at least. What’s the plan now that Internet Explorer is deprecated?
Regards.
Hi all,
Regards.
Hello, eM Client is built on the .NET framework which uses system components rather than IE exactly. However we’re now moving to Chromium with the upcoming release of eM Client 7 which will allow us to handle a lot of things differently regardless of your IE, Edge browser.
This means the application will be using webkit core instead of the previously used IE components.
Thanks Paul.
Is there any time frame on version 7?
Regards.
Rumor has it this summer…
