What is up with eM Client and modal dialogs being hidden?
Guys… wtf? I had to work for 20 minutes to get eM Client to INSTALL. Why? a modal dialog being hidden behind windows setup.
Then, another halt when I first tried RUNNING eMClient. Why? Another hidden modal dialog!
What is going on? is there some bit of software engineering training that eM Client missed? Honestly, this is laughably ridiculous! Y’all gotta fix this glaring problem.
Sry I carn’t replicate that in Windows 11 or Mac Sequoia with the latest eM Client V9 or 10.
Could be something possibly eg: optionally installed in your OS running in the background or running resident causing the dialogue boxes to go behind where normally they are in focus in front on install and when inside eM Client.
So try disabling “all non os user related background tasks on startup” and then reboot. Then uninstall eM Client and then reinstall the latest version via the release history page and see if that works then. You will then know if it’s something user related starting up causing it.
Failing that if you have a current active paid Pro or Personal version go to the VIP support page and login and lodge a support ticket.
Same here. I’ve never experienced this with any of the macOS versions of eM Client.
Perhaps it was only under Windows and, as you say, with a particular user configuration?
