Hi developers
I have add webex as meeting provider.
Would it be possibile to see in the calendar the planned meetings, not only those created from EMClient?
Thank you
Best Regard
Sandra Chiera
Hi developers
Thank you
Best Regard
Sandra Chiera
Would it be possible to see in the calendar the planned meetings, not only those created from EMClient?
I would think all you have to do (similar to how Google Calendar & Outlook Calendar) is add the other workplace webex shared meeting calendar into your webex calendar online “via a shared url address”, which should then show up automatically in eM Client calendar.
Or add the workplace webex workplace shared meeting calendar directly in eM Client as another calendar, but I would personally first try adding it online in your webex calendar account to then show up automatically in eM Client. Your Webex tech support should be able to help you with that.
Thank you cyberzork
I cannot find how to generate the webex calendar url (in order to see all meetings).
I have written to webex support too.
Thank you
Best Regard
Sandra Chiera
