View and restore single mails out of backup
I have some emClient Backups and lost some mails. What is the best way to view the mails inside these backup and restore only single ones. I don’t want to do a full restore as I don’t want to affect my current instalation. Thanks for any advice.
There is a way to retrieve selected data from the backup:
  1. Disconnect the computer from the Internet. This is important!
  2. Go to Menu > Settings > General > Backup. Disable Periodic Backup if it is selected and click on OK.
  3. Make a backup using Menu > Backup, so we can come back to the current database later.
  4. Restore the old backup that has the data you want to retrieve.
  5. Export that data you need. You can do that using Menu > File > Export > Export email to eml files. You can select whole directory trees, so it is fairly easy to do.
  6. Restore the backup made in step 3.
  7. Reconnect to the Internet.
  8. Import the data from step 5 using Menu > File > Import > Email (eml).
Thank you. That way I get to my mails. Unfortunately it was an IMAP-Account and the mails are not fully synchronized. The text is there but not all of the attachments.
em Client then does not export the mails not complete downloaded. But the text of mails is almost there.
Is there a way I can export the mails as they are, even when they are not complete downloaded?
If they were not fully cached, and have been removed from the server, then no. The export will be incomplete.
Going forward, go to Menu > Accounts and click on the IMAP or Exchange tab for the account. Scroll down to Sync Options, tick both of them, and click on Save & Close. That will fully cache the messages.
I followed your approach with opening the backup. That works. And I see a lot of mails with its attachments.
As example, let’s take one mail where the text is available and I CAN open the pdf-attachment in the pdf reader. But when I try to export or save this mail emClient does stop doing this with this message:
As the data is there, how can I get it exported?
eM Client packages backups as standard .zip archives, but running its native File > Restore menu command is an all-or-nothing operation that overwrites your active %APPDATA%\eM Client directory with the historical database state. The archive contains monolithic SQLite databases (mail_data.dat, folders.dat, and corresponding Write-Ahead Logging .wal journals) rather than discrete .eml files. Restoring this container directly wipes any mail received between the backup timestamp and today.
To surgically recover individual messages without overwriting your current profile, extract the backup .zip to a temporary directory on disk. Launch a secondary or portable instance of eM Client (or use the /db parameter from the command line to redirect database initialization to your unzipped folder). Once loaded in this isolated session, locate the specific emails, select them, and choose File > Export > Export to .eml. You can then return to your primary eM Client profile and drag the exported EML files straight into your active inbox.
If digging through SQLite datastore containers feels excessively fragile whenever you need to backup mail, Mail Backup X eliminates monolithic restore lock-in. Its granular snapshot engine allows you to browse historical backups via an integrated visual viewer, search across full message text and attachments, and restore single messages directly to live servers or desktop applications without touching active local databases.
