Vertical scroll screen distortion
Using version 10.3.1738 (984d31d)
When scrolling through an email there is a wavy horizontal through images.
Moving chrome over to the same screen and all other programs don’t experience this problem.
I appreciate any advice as to how to solve the problem.
All I can suggest is to try eg: different videos resolutions to see if that makes any difference, and also check you have the latest video driver for your specific video card.
Thanks for the advice. My RTX-4060 has the latest drivers, and all other programs scroll vertically fine without any horizontal wavy lines. Changing the video resolution doesn’t help - there seems to be some problem with emClient?
Anyone know what else to try?
Thanks!
