Ich werde dauernd nach meinem Kennwort gefragt. Ich weiß es aber nicht mehr. Wie komme ich an ein neues Passwort bezw. kann ich mein altes zurücksetzen?
Depends on what password you are asking about.
- If it is the password for your email account, your email provider should have a page for you to recover a lost password. Once you have the password, start eM Client and when it connects to that server it will again ask for the username and password. Once you have entered the correct information, make sure you tick the Save password option. It will be stored in the application and not ask you again.
If this is your eM Client startup password, there is no way to reset that. You can delete the C:\Users\yourusername\AppData\Roaming\eM Client\settings.dat file, which will remove the startup password. Unfortunately it will also delete some of your settings, but all your data will still be there.
If it is something else, please let us know what the password is for.
