Hi. Problem with authentication with Yahoo during upgrade to V10 resulting with an error massage ( CalDAV )sync of [email protected] failed due to the following error. a.m… bad request. A small red triangle appeared at the screen top.
During the final authentication process our two accounts appeared with the need to authenticate which i did with my account [email protected] but no facility to authenticate the second account [email protected]. Now all my emails appear in both our accounts and the emails of the second account do not show.
Please advise.
Mike
Cyberzork gave me some steps to follow to fix the “same emails appearing in all accounts” problem.
You have to delete the account that isn’t showing correctly (this can be done in the Accounts menu option) and then re-add it again via the menu button->Accounts->Add Account
This will require you to log into your Yahoo account at the end (might need to use full @sky.com address) and accept the dialog which will be displayed to allow eM Client to access the Yahoo account.
The forum post is here:
Hi Neil. Thanks for the suggestion to remove the second account and then reinstate. It worked perfectly. Never used this forum before so i hope this note is ok. Mike
