I recently upgraded and bought the licences (times 3 for all my machines). So far, I have only installed on one Mac, but it is crashing a lot. Often, when I close my laptop and then open it again a while later, eM Client has unexpectedly quit and needs to restart (with all the necessary checks etc.).
This has basically never happened with the older versions.
(Also, for everyone considering to upgrade… if you are not interested in using AI features, there is no reason other than you probably need to do it, if you want to stay with eM Client. Otherwise, it is hard to see why an upgrade should be necessary…)
As you have just bought 3 licences recently if you have already tried the latest V11.0.1201 version via the release history page and its still crashing, then suggest then you contact offical support who can then investiage that for you. Go to the VIP Support page and login and lodge a support ticket.
That can happen if you are eg: shutting the laptop lid with eM Client still open, as it normally forces sleep and can kill the client which also can happen on Windows. So make sure eM Client is fully closed before shutting the lid down if you are doing that.
Or alternativily if you want to leave eM Client open, power off in sleep mode and then shut the lid after its turned off to avoid it having errors on startup. I do that on my own Mac to then resume quicker than normal power on with eM Client still open.
