V10 KI-Add on missing
After the Update I tried KI again but this time I get the message that the KI-Add on is missing and I have to buy ist.
In my license it should be included and it worked with v9. Someone else has this problem?
AI is a new feature in version 10.
Unless you have a new subscription-type license, it is not included in your license, but as an optional addon that you can purchase.
It is not possible with version 9.
in the previous version I had alle this functions
When I buy a license it also says “AI Add-On included”
I did buy with Lifetime Updates and AI worked and now you tell me, it is not included anymore?
AI was free during the beta test for all testers. But the beta test is over and now you need to have a license. AI is not included with a Free license, nor with existing Pro licenses, nor in other new one-time payment licenses. If you want to use AI with those licenses, it is an addon subscription.
Yes, that is a new Personal subscription license. If you purchase one of those, you will have AI included in your subscription.
