Since the last update, when I use the dialog box to move a message from the Inbox to a Folder it locks up the program. Anyone else having this issue? I’m on Windows 10
No, not experiencing it. Sorry Mark.
What you can do though, is download the previous version from http://www.emclient.com/release-history, then close and uninstall eM Client. Your data and settings will be fine, so don’t worry about that. Then install the older version and hopefully no more problem.
