Since the version 11, when properly closing emClient it apparently every time closes incorrectly, causing on restart the emClients wants “to check for corrupted database”, which easily takes another 30 minutes (!!!) before the mail client actually starts. I can understand the maildatabase integrity needs to be secured, but it is not acceptable that emClient apparently does not properly close, and for sure it is not at all acceptable that such database check takes this long.
Horrible experience, if not resolved I will move away.
I now see also comparable post by Rasworth “Beware closing with X vs Exit”. Indeed as any normal user, I am closing the app with the X on topright corner. I now understand that in this v11 this X has a different behavior than simply closing the app ?
My dear emClient developers, please have this corrected to the normal, common “X” behaviour, ie. close the app.
Secondly, do something about this enormous time lapse for emClient to execute that check on corrupted database.
I’m not having the same issue, I close my two instances of em Client with the X (in Windows) before powering off the laptop. Startup the next time I use the laptop is normal, no checking corrupt databases.
Any chance there is stil some pat of em client still open such as a new mail dialog window? Or settings? So then the computer is shutdown but some part of em Client is still running and abruptly ended?
I never use Exit. Are you on a Mac by any chance? I’m on Windows.
