I updated to W10 20H2 and now eM client no longer works. Ive uninstalled and reinstalled no change. It worked last night then this morning errors no matter what I do. Only thing I did between then and now was update windows on my newly built pc
Close and uninstall eM Client, making sure NOT to delete the database folder when asked. That will ensure all your data and settings are there later.
If it exists, delete the C:\Program Files (x86)\eM Client folder.
Download and install the latest version from here: https://www.emclient.com/dist/latest/setup.msi
Restart eM Client.
I have done that twice and still no luck. I even deleted the registry entries and fresh install and still same issue persists
Is there anyone I can send the logs to or anything that would help with a solution?
FYI I reinstalled windows 10 fresh and problem went away for now
