when I updated my email was imported but my calendar data was not
would like to know how to get it back
which Calendar data did you lose?
What mail account was it connected to?
I only have one email account so it was attached to that (the same one as the emails that were imported)
so the calendar was synchronized to the server, not a local calendar?
Are there any errors in Tools>Operations window?
Is your mail account set up using IMAP?
I think it was a local calendar - I set it up using eM Client - I rarely log into my email account directly - I almost always us eM Client.
if you have a calendar service connected to your account, it is possible eM Client would synchronize it.
Thats what I was trying to find out.
Are there no errors then?
Have you migrated your database during the eM Client 7 setup or used the Menu>File>Import>Import from eM Client 6 option?
during the setup process the emails were imported
I just now used the menu>import from eM Client 6 option but still no calendar data - not aware of any error messages
Hello Olivia,
did you check all the data and waited for import to finish?
Yes - I checked my email account , local folders & archive
and it seemed to finish okay
