Unread msg on the Mail Pane: when a folder is collapsed, there’s no indication whether there are unread msg or not!!
That’s really bad, I know there’s an Unread folder, but why hide unread msg from collapsed folders??
Hi, if you collapse whole account in left side bar and nothing is shown then it works like designed.
If you collapse only some of email folder/s like “Inbox” then you should still see unread numbers.
Can you tell me what is your case?
Jan
My case is the second one, I collapse only some folders.
could you make screenshot of it and post it here please?
Jan
