I am unable to print or print preview any e-mail. I do have the latest version of Internet explorer and am able to print and print preview within it. How do I fix this?
Hi Gary, what version of eM Client are you currently using on your computer, can you please check the exact version number in Help > About? Are you seeing any errors when trying to use the Print / Print preview feature?
Paul
I’m facing exactly the same problem using the latest available emClient version. Don’t get any Errors but empty Sheets. Maybe the header and foot is printed, don’t know exactly right now.
Don’t know if it’s related to all e-mails or just a some of them. I will check this later on. Noticed this problem some days ago without taking any further action so far.
Right now after reading this posting here, I now remember about having the same issue here.
Paul, I’m running EM Client Version is 6.0.21372.0
Yes There are errors in print preview. The page viewed is blank except for header and footer. When print is pushed, printed page is blank except for header and footer. The problem is on all email. The computer is an HP Laptop running windows 8.1. 64 bit version. I uninstalled and reinstalled IE version 11.0.9600.17498, update Versions 11.0.15 (KB3008923) The print preview function works in IE as it should. The problem persists in EmClient.
Thanks for your help,
Gary Broom
Hi Gary, can you please make a screenshot of the print preview window when the issue occurs? Are you trying to print out a single message or multiple messages at once? Can you make sure the content of the message is available (downloaded) into eM Client, e.g. the message content can be displayed in eM Client’s interface?
Paul
I not able to figure out how to make a screen shot. All that shows is the entire “Page” of the downloaded email. The page is blank holding no content, however “page 1 of 1” appears in the top right corner and "File:///c:/windows/termp/x999zvig.htm: in the lower left corner with today’s date in the lower right corner. I am trying to print out one message at a time. I am certain the message content has been downloaded since I can see the entire message in the message window of EMClient.
You should be able to create a screenshot using the built-in Snipping Tool application, or find a program for screen capturing here.
Paul
Paul, I think I got it with the snip tool. Now I can’t figure out how to get it to you. I can’t do a paste of the file in this reply. If you can send me an e-mail address I can reply to, I’d be happy to attach it. Or just tell me what to do with it. Apologies for my novice user status.
Gary
Ok, here you are, Paul.
As I’m seeing the same problems as the OP, I’ve linked a file that shows the issue, a file with a screenshot of the original message and last but not least the original mail source (some information is obuscated though).
Print Preview (using the latest available emClient version, btw.) https://dl.dropboxusercontent.com/u/11147714/PrintPreview.jpg
Original message as emClient shows in its message preview
https://dl.dropboxusercontent.com/u/11147714/Original%20E-Mail.jpg
Message source
https://dl.dropboxusercontent.com/u/11147714/Message.txt
Perhaps those files are somehow helpful.
cu,
Michael
you can attach a screenshot when posting using the icon below showing a photo camera.
“Below” means when you are composing a new comment here a toolbar appears on the bottom of the text box where you enter your comment text.
HTH,
Michael
Paul, attached is screen shot of problem,
Thanks Mike for the “how to”
Gary
Seems like the same issue I’m currently facing here. Perhaps this information will help Paul and his team to find a solution…
Cheers
Michael
Hi Gary, Hi Mike, thank you for the submitted data and the source code of one of the messages, I’ve tried to replicate the issue and was able to reproduce successfully using the above email message, I’ve submitted the issue to the developers and we’ll be looking for a fix for future releases.
However it seems it might be due to specific formatting of the message, hopefully we’ll be able to resolve the issue as soon as possible.
Sorry for the inconvenience,
Paul
I have the same problem running EM Client version 6.0.21372.0 with win7 home premium 64bit.
Starting EM Client “As Administrator” with right clicking circumvents the problem: printing is now possible.
Paul, has this issue already be addressed?
I am having this same issue running version 7.0.26687.0 on windows 10. Has a solution to this problem been found? I have tried running EM Client as administrator that did not work. I had this same problem before and switched email clients because of it was hoping that it had been resolved by now.
