Two reminders from Google calendar keep reappearing when EmClient starts up. Syncing Google calendar. I think maybe after I deleted an old recurring event in the google calendar.
Version 7.1.30794.0
Do have a screenshot but don’t know how to post it.
Yes there is . Dismiss and snooze . When I select one nothing happens and the dialog window stays on screen. I have to minimize the window to be able to use mail. Regards
Upgraded to latest version and delete and readded account. No luck.
After some research I think the problem is related to a google calendar sync issue. Same calendar seems to be syncing twice. One copy of the sync is good and the other seems to be just those two reminders. I have attached two screen shots of the expanded reminders (good and bad) The good has a folder of [email protected]…
I
The sync that shows folder internet calendars/gmailsrv is syncing but also contains the two reminders that were deleted and show up when emclient starts. The other sync seems to be working ok.
This is separate from your Google Calendar setup in your accounts, so you can go ahead and just delete it. Right-click on the calendar and choose Delete.
Yes I did add a calendar. I don’t have a calendar tab on the left of screen. Could it be because I am using the free version. Please see screenshot. Thanks for your assistance, it is much appreciated.
