Is it possible to show two lines per email, one for the header and one for the first words of the content, assuming that the side/below panel is deactivated? When there is big amount of emails on a small screen, it helps a lot to focus on the more relevant emails. Thank you,
Hi Carlos
Menu > Settings > Mail > Read
Untick “Use compact layout …”
Select “Always use compact layout”
Apply
