One particular sender’s emails always go to spam. So I tried to put them in my “white list”, and I got “Local white list not supported”. So I put them in my safe senders list. But the problem still exists.
If a sender email is allways going to the Junkmail folder and white listing or adding them to your safe senders list online in your mailbox hasn’t helped, then you might have accidentally added the sender to the Blacklist or accidentally added them in a Custom Rule which then is automatically to the Junkmail folder.
So check both of those and if the sender is not in the Blacklist or Custom Rule, then it normally means your mail box online is detecting something in the sender message header, subject or body of the email as possible spam so is automatically moving it to the Junkmail folder.
So next when that senders email arrives in your Junkmail go online into your webmail Junkmail folder and “mark that email as Not Junk” That will train your mailbox online to keep that sender in your Inbox in future. Sometimes with certain mail server mailboxes you might need to do that a few times till it learns to keep it in your inbox.
If the sender is still automatically going to the Junkmail folder even after doing the above a few times, then I’ll would contact your mailbox technical support to advise as could be it’s happening due to the senders ip address or senders server etc.
Thanks, cyberzork, but I’ve tried all that. I had also used a rule to send the emails to my inbox, and that didn’t work. (It’s a gmail address, so it can’t be thinking it’s something sinister.)
I won’t contact tech support as this is a minor inconvenience, not a disaster. One of life’s little mysteries.
domingo 22 noviembre 2026 :: 0930hrs (UTC +0100)
Hey @GeoffM
I wou;d NOT make that assumption.
¡Solo la muerte está garantizada!
skybat
¡Buena suerte!
Hablo español, luego portugués, inglés, francés, italiano y alemán
con conocimientos de varios otros idiomas incluidos griego y ruso
