Non so come trasferire i contatti da Incredimail a eM. Qualcuno mi aiuta?
Grazie
f your contacts are synced with an online provider such as Gmail or Yahoo, just add the same account in eM Client it will sync all of your contacts.
You can also export your contacts from Incredimail as .vcf or .csv then import them into eM Client using Menu > File > Import.
If Incredimail is still installed on your computer, in eM Client use Menu > File > Import > Incredimail.
