Hi the translation no longer works!! Error occurred during translation
There may be some interruption in the connection with the server. Can you try again?
Hello, I have the same problem. No translation, same error, server is OK. Still the same problem after the update. Program Version is 8.2.1659 (845a639). Thanks for help. Lenka
It is working.
Can you please try again.
Not working, same problem …
As a test, can you completely disable any anti-virus, firewall, proxy or VPN, then try again.
Sometimes even restarting your router may resolve this.
